1995 Mercury Sable No Start
TALLPINE
i have a 1995 mercury sable wagon,3.0 engine,
130,000miles. engine turns over good but it wont start.
please help!
Jan 29, 2007 at 3:24 PM
MERLIN2021
  • 17,250 POSTS
First you need to check for spark, pull off a plug wire put it near ground source and crank engine. You should see a blue spark, if notcheck wires and coil pack. If you get a spark check fuel. There is a valve on the fuel rail to check the pressure. Good luck.
Mar 4, 2007 at 8:39 PM
Suggested Repair
Check for spark by holding a plug wire near a ground source while cranking; a blue spark should appear. If there is no spark, inspect the plug wires and coil pack. If spark is present, check fuel pressure at the valve on the fuel rail.
Conversation Summary
The owner of a 1995 Mercury Sable wagon with a 3.0 engine and 130,000 miles says the engine cranks well but will not start. The expert advises checking for spark first, then the wires and coil pack if spark is absent, and fuel pressure at the rail if spark is present.
