I have a 1995 Mercury Sable w/3.0 liter 6 cylinder. My problem is that the engine seems to lose power when climbing upgrades to the point that it is constantly back-shifting to a lower gear to maintain speed. Overall performance is becoming poorer and gas consumption is up. I also get an intermittent check engine light that appears when the A/C or defrost s turned on. It stays on for several minutes then goes out. I don't know if the light is related to my problem or not. To me it seems as if there is something inhibiting the exhaust flow that may be causing the problem because when I first drive it it seems to have alot more power; as the engine warms up it gets worse. I have done tuneups and checked the transmission and so forth and with 166,000 miles it's definately high mileage. It may be time to rebuild/replace the engine but I'm hoping there might be a cheaper solutiion.
Jun 14, 2009 at 6:42 AM
