HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Mercury
Sable
Fuel System
Fuel Pump
Relay
Location
1994 Mercury Sable
PUZZLE7149
MEMBER
1994 MERCURY SABLE
1994 Mercury Sable 6 cyl
fuel pump relay where is location for 1994 Mercury Sable
Sunday, May 23rd, 2010 AT 3:33 PM
MECHANIC
Front radiator support
The Fuel Pump Relay is part of the Integrated Control Relay Module, is located at the front of the engine compartment, on the upper radiator support.
https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Sunday, May 23rd, 2010 AT 4:37 PM
Please
login
or
register
to post a reply.
Related Fuel System Fuel Pump Relay Location Content
1994 Mercury Sable No Power To Fuel Pump
After Pulling Into Our Driveway, Our Car Shut-off While Idling Briefly. Car Would Not Restart. So I Checked The Fuel Pump Emergency...
Asked by
Sonex963
1994
MERCURY SABLE
1997 Mercury Sable No Fuel Pressure
The Car Recently Died In The Road And Is Not Getting Fuel Pressure. Could This Be A Fuel Pump Or Something Else?
Asked by
jkruby2
1 ANSWER
1997
MERCURY SABLE
1999 Mercury Sable 99 Sable Fuel Pressure/starting...
Hi, My Sable Had Been Running Rough(hesitating, Rough Idle And Stalling) And Finally Ran So Rough That I Was Barely Able To Limp It Home...
Asked by
Sleeperservice
1999
MERCURY SABLE
How Do You Know If Your Fuel Pump Is Bad
Car Idles Rough When In Gear. Died And Wouldnt Start With No Preasure At The Schrader Valve. Replaced Fuel Filter After Letting Car Sit For...
Asked by
kmhess
1 ANSWER
2001
MERCURY SABLE
1998 Mercury Sable
Other Category Problem 1998 Mercury Sable 97309 Miles Won't Start - Check Engine Light On. Trying To Locate Fuel Pump Shut-off...
Asked by
grfrog
1 ANSWER
1998
MERCURY SABLE
VIEW MORE
How to Use a Test Light
Fuel Pump Replacement
How to fix an engine that wont start
