1989 Mercury Marquis Check Engine Light
MERCURY
TEXASEXX
1989 Mercury Marguis, 104,000 miles 5.0L engine
Car has been well maintained.
After cruising on at 55-65 mph, upon decelerating, the yellow 'check engine' light flashes briefly. No other incidents observed.
I assume that a computer code check will reveal exact problem, but what is most likely cause(s)?
Jan 26, 2007 at 1:35 AM
SERVICE WRITER
  • 9,123 POSTS
Generally a flashing check engine light is a sign of damage being caused to the converter. The codes will aid in finding the source of the problem, but it is a starting point with which to work with. Post the codes and we can go from there.
Jan 27, 2007 at 12:38 AM
Suggested Repair
Retrieve the diagnostic trouble codes and use them as the starting point. A flashing check engine light generally indicates a condition that can damage the catalytic converter.
Conversation Summary
The owner of a well-maintained 1989 Mercury Marquis with a 5.0L engine reports that the yellow check engine light flashes briefly when decelerating after cruising at 55-65 mph. The expert says a flashing light generally means the catalytic converter is being damaged and recommends retrieving the codes to identify the source.
