Engine Warning Light
MERCURY
TEXASEXX
1989 Mercury Marguis, 104,000 miles 5.0L engine
Car has been well maintained.
After cruising on at 55-65 mph, upon decelerating, the yellow 'check engine' light flashes briefly. No other incidents observed.
I assume that a computer code check will reveal exact problem, but what is most likely cause(s)?
Jan 26, 2007 at 1:35 AM
SERVICE WRITER
  • 9,123 POSTS
Generally a flashing check engine light is a sign of damage being caused to the converter. The codes will aid in finding the source of the problem, but it is a starting point with which to work with. Post the codes and we can go from there.
Jan 27, 2007 at 12:38 AM
