1997 Mercury Mystique White Smoke
KEV1962
I have white smoke coming out of my tail pipe. What could be the cause. If the dpfe is faulty could this be the probllem? I do not have water in the oil.
The car is a 1997 Mecury Mystique 120000 miles the engine size is 2.0
Mar 25, 2007 at 4:46 PM
MERLIN2021
  • 17,250 POSTS
There is a recall on 95-97 Mystiques for wiring harness degradtion. P0401 codes if present indicates your car may be covered under the recall.
Insufficient flow. As for the white smoke...usually this is anti-freeze being burned off. Do a compression test. U may need a head gasket!
Mar 26, 2007 at 12:30 AM
Suggested Repair
Check for a P0401 code and the 1995-1997 Mystique wiring-harness recall related to insufficient EGR flow. White tailpipe smoke more likely indicates coolant being burned, so perform a compression test and inspect for a possible head gasket failure.
Conversation Summary
The owner of a 1997 Mercury Mystique 2.0 with 120,000 miles reports white smoke from the tailpipe and asks whether a faulty DPFE sensor could cause it, noting there is no water in the oil. The expert says a 1995-1997 Mystique wiring-harness recall may apply if a P0401 insufficient-flow code is present, while white smoke usually indicates antifreeze being burned and calls for a compression test and possible head-gasket repair.
