1998 Mercury Mystique Runs sometimes and then will not
PINECONE9678
MEMBER
1998 MERCURY MYSTIQUE
4 CYL
2WD
AUTOMATIC
81,576 MILES
My air conditioner blower runs sometimes and then it will not come on. When it does come on it blows good cold air or heat depending what I have it set for.
What could be causing it?
Thank you for any information.
updated 7/9/09
Where is the blower located?
SPONSORED LINKS
Tuesday, April 7th, 2009 AT 4:39 PM
KHLOW2008
MECHANIC
Hi pinecone9678,
Thank you for the donation.
Most likely the blower motor is failing. When the problem happens again, turn on AC and give the blower motor housing some vibrations, tapping (banging) it with your fist and if it starts up, the blower motor is due for retirement.
Let me now the results.
SPONSORED LINKS
Wednesday, April 8th, 2009 AT 2:40 AM
KHLOW2008
MECHANIC
Hi, You should use the " reply to question" link so that the post would be updated in the forum and email notification would be received by whoever handling your case.
Updating your post would not be notified.
The blower motor is under the dash on passenger side, behind glovebox.
