2007 Mercury Mountaineer Cylinder 5 Misfiring
JNMOSQUEDA
Shakes or Wobbles problem
2007 Mercury Mountaineer 6 cyl Two Wheel Drive Automatic 71K miles
Do you know what could cause for my check engine light to come on, as well as Gas cap light? I went in to an autozone and purchased a new one after clearing the code on my OB II, for a loose cap or bad cap. After 3 days it came back, but not only that but cylinder 5 is misfiring. I tried switching the wires to distingish if it was the wire and/ or coil pack, but got the same code (cylinder 5 misfiring). I went back to autozone and purchased a coil pack, but still the same what else could it be?
Apr 23, 2010 at 8:10 AM
  • 31,937 POSTS
Hi there,
Thank you fore the donation,
With a single cylinder miss fire, check the plug, injector, compression and vacuum leaks around that cylinder, start here.
mark (mhpautos)
Apr 23, 2010 at 9:12 AM
