Where do I add transmission fluid
2004 MERCURY MOUNTAINEER
87,000 MILES • 6 CYL • 2WD • AUTOMATIC
DOLFANDAVE
I just drained and changed the transmission filter, but I noticed there is no dipstick to add the new fluid. So where exactly can I try to add the fluid?
Mar 14, 2010 at 3:46 PM
  • 110,194 POSTS
The fluid is installed from the oil pan. Here are diagrams to help you see how to do the job:
Cheers
Mar 23, 2010 at 7:41 AM
JSOUSE27
I accidentally drained the transmission fluid instead of the oil when I was going to change the oil.
Aug 25, 2018 at 7:22 PM (Merged)
ARACHRISTINEDAVIS
How do you check the transmission oil in a sealed transmission? And can you replace the oil in a sealed transmission?
  • 110,194 POSTS
The transmission fluid can be checked for level. There is a bolt in the side that is removed. If the fluid comes out, level is okay. Service work should be done by a dealer.
