2004 Mercury Mountaineer DTC CODE
2004 MERCURY MOUNTAINEER
107,321 MILES • 6 CYL • AWD • AUTOMATIC
BIGHURT16
Code came up on computer p0775 replace b-solenoid pressujre door malfunction. solenooid was replaced and code returned after 25 miles also problem with transmission hesitating going into gear returned. After replacing solenoid a transmission flush was done and problem returned
Apr 28, 2010 at 4:06 AM
MERLIN2021
  • 17,250 POSTS
To diagnose these you need a Ford scan tool, this can command the the solenoids to operate while the wires, and solenoids are tested...It might be worth the 1 hour labor to test it at Merc dealer.
Apr 28, 2010 at 7:54 AM
