I need to know where the key-less entry module location is?
May 26, 2006 at 3:00 PM
The keyless entry module, also called the body security module, is behind the interior panel on the rear passenger-side cargo area. Remove the plastic fasteners and screws with simple hand tools to access it.
The owner of a 2002 Mercury Mountaineer asked where the keyless entry module is located. The expert said it is the body security module inside the rear passenger-side cargo panel and can be reached by removing the panel fasteners and screws.
