2000 Mercury Mountaineer wrong transmission fluid
ANGELSINGS95
Transmission problem
2000 Mercury Mountaineer Automatic 119000 miles
I put about a half-quart of Multi-Purpose ATF in a 2000 Mercury Mountaineer which requires Mercon V; will this damage the transmission? Do I need to get the ATF changed?
Sep 5, 2010 at 2:31 AM
MERLIN2021
  • 17,250 POSTS
1/2 quart isn't a lot in a 10-13 qt. system, but Ford recommends NOT mixing fluids, so I would get it flushed at a place with the machine. Most oil change shops use the refilling station...
Sep 5, 2010 at 2:37 AM
