1999 Mercury Mountaineer rotors
1999 MERCURY MOUNTAINEER
100,000 MILES • 6 CYL • 4WD • AUTOMATIC
EDDIEVIG
what do I need to do to replace the front rotors, is there a lot of things to remove first I haven!t taken anything off yet does it involve removing front axle bolts or nuts I have some brake work but never on 4 wheel drive, thank you
Aug 8, 2009 at 2:02 AM
MERLIN2021
  • 17,250 POSTS
Removal & Installation (4WD Models - Except Super Duty Pickup) 1. Raise and support vehicle. Remove wheel. Remove anchor plate and caliper assembly. See DISC BRAKE CALIPERS & PADS. Remove rotor. 2. To install, reverse removal procedure. Tighten bolts and nuts to specification. See TORQUE SPECIFICATIONS. Slip ons...
Aug 8, 2009 at 5:02 AM
