1999 Mercury Mountaineer Part in transmission pan
1999 MERCURY MOUNTAINEER
140,000 MILES • V8 • AWD • AUTOMATIC
DMCNABB
While pulling off the automatic transmission filter, a part which looks like a top with an O ring fell out. I cannot find where it goes. It is about 3/4" dia. with a shaft of about 1/4" dia X 1" in length.
Feb 20, 2010 at 6:34 AM
Hi dmcnabb, Welcome to 2carpros and TY for the donation Sounds like you're talking about throttle pressure limiting valve it goes in a hole on one corner of the tranny housing-See pic below if it similar to what you trying to describe
https://images.2carpros.com/forum/automotive_pictures/12900_Picture_6_1.jpg
Feb 20, 2010 at 8:24 AM
DMCNABB
Yes, This is the part but I could not find where it goes.
Sorry, your picture is very fuzzy.
Please send a description of where it goes or a clearer picture.
Feb 20, 2010 at 8:17 PM
What I use to illustrate what you have described is for a C4 Ford Auto Tranny not for yours
The valve goes to the lower part of the valve body.I'm searching thru Mit1 and Alldata but nothing is coming up on this throttle pressure limiting valve where its position-
Sorry this the best I could do
Feb 21, 2010 at 9:14 AM
DMCNABB
I found out through an other source that it is a plug that the factory installs after the fluid is added but before the fill tube and dipstick is installed. When these are installed, the plug is pushed by the fill tube and ends up at the bottom of the pan.
So, basically, it is not an issue and can be trashed.
Dan
Feb 22, 2010 at 3:56 AM
2 LINSEY
  • 287 POSTS
We appreciate your donation and look forward to helping you in the future. Thank you
Mar 2, 2010 at 4:16 AM
