2000 Mercury Grand Marquis Wiper Smear
GEO200MPH
i have a 2000 mercury grand marquis. my drivers side wiper does not clean the windshield like the passenger side. it looks like it isnt making enough pressure on the windshield to sweep the water away, instead it smears it. ive tried many different brand wipers. rain x, anco. i have bosh excel. there 24$ each and i still have the same problem. any soloution????
george
Jun 2, 2007 at 6:56 PM
2CARPRO JACK
  • 11,533 POSTS
The spring in the arm itself may be weak or the arm has been bent.
Jun 3, 2007 at 12:56 AM
GEO200MPH
[quote:aea3cb9abf="justanold"]HELLO! I'm curious. this smear, is it fairly uniform or more splotchy? 8) 8) 8)[/quote:aea3cb9abf]
its pretty uniform. last night it was pouring down raining, the passenger side would sweep it away clear no problem. th driver side would "skip" the water away. then it got to a point where the wiper looked like it was just moving on top of the water instead of on windshield. tis kind of hard to explain.
but its not just heavy rain that does it. a cup of water thrown on the windshield or washer fluid and the wiper has a hard time sweeping it away.
maybe i could email you a short video.
Jun 3, 2007 at 5:42 AM
Suggested Repair
Inspect the driver's side wiper arm. A weak arm spring or a bent arm can reduce blade pressure and cause smearing even with new blades; replace the arm if it is weak or bent.
Conversation Summary
The owner of a 2000 Mercury Grand Marquis reports that the driver's side wiper smears and skips water instead of clearing the windshield, while the passenger side works normally. Multiple brands of blades did not help, and the problem occurs in heavy rain and with light water or washer fluid. The expert suggests the wiper-arm spring may be weak or the arm may be bent.
