1989 Mercury Grand Marquis Reverse Lights
SNORTEE690
1989 Mercury Grand Marquis; 85,000 miles.
all my brake lights work, and my directionals do too, but my reverse lights wont work. there is no juice going to them at all.
Dec 10, 2006 at 5:46 AM
BACKYARDMECHANIC
  • 337 POSTS
The switch that controls that is located on the transmission. And when the car is in reverse it engages that switch. It is accesible from the outside of the transmission. The switch either needs to be adjusted or replaced. Check at the switch to see if ther is power going in and coming out. If there is no power going out then the switch is bad and needs to be replaced
Dec 10, 2006 at 9:18 AM
Suggested Repair
Check the transmission reverse-light switch, which is accessible from outside the transmission. Verify power going into and out of the switch with the car in reverse. Adjust the switch if needed; if power enters but does not leave the switch, replace it.
Conversation Summary
The owner of a 1989 Mercury Grand Marquis reports that the reverse lights have no power, while the brake lights and turn signals work. The expert says the reverse-light switch is on the outside of the transmission and is engaged in reverse. They recommend checking for power in and out of the switch, then adjusting or replacing it if it does not pass power.
