1996 Mercury Grand Marquis Dash Lights Out
RESHEPHERD
I have a 96 Mercury Grand Marquis LS, 125,000 miles. A few days ago I was driving in the rain and decided to turn my headlights on, when I did all my dash lights went off. I couldn't see my speed or nothing else. As long as I don't turn my lights on, the dash lighting works fine. Could you tell me what could be wrong?
Thanks,
Russ Shepherd
Jan 19, 2007 at 5:03 AM
BOOTDOG
  • 665 POSTS
when you cut the headlights on, the dash lights will be dimmer then if you didn't have the headlights on. i would make sure that the dimmer switch is not turned down. look there first.
Jan 19, 2007 at 7:32 AM
Suggested Repair
Check the instrument panel dimmer switch and make sure it is not turned all the way down. Dash lighting is normally dimmer with the headlights on than with them off.
Conversation Summary
The owner of a 1996 Mercury Grand Marquis says the dash lights go out when the headlights are turned on, but work normally with the headlights off. The expert notes that dash lights normally dim with the headlights on and recommends checking that the dimmer switch is not turned down.
