1991 Mercury Grand Marquis Timing Marks
When was the last tune up? try dissconnecting the neg battery cabel for about 20 sec. This will clear the memory, and the computer will re-learn by your driving habits...where you have the engine in this state, and zooming in on it, why don't you reset the marks any way!
Suggested Repair
The pictured chain deflection is considered normal. Remove the timing chain and rotate the crankshaft so the timing marks match the camshaft before reassembly. Also disconnect the negative battery cable briefly so the computer can relearn, and note any remaining hard-start or rough-idle symptoms.
Conversation Summary
A 1991 Mercury Grand Marquis ran poorly after an overheating failure and water-pump replacement. Compression was within specification, and the owner suspected jumped timing because the chain had play and the marks were slightly off. The expert said the pictured chain deflection looked normal, asked about codes and symptoms, and recommended clearing the computer memory. After the owner described a hard start and rough idle with no check-engine light, the expert advised removing the chain and rotating the crank to align it with the cam.
