1987 Mercury Grand Marquis Fuel Pump Whine
MIAMIBOB
I just replaced the original Fuel Pump on my '87 Grand Marquis. It has almost 111,000 miles on it and I replaced the pump with a Carter pump. When I turn the key but DO NOT start the car I can hear the pump "clicking". It is lower but somewhat audible when the car is running. My question is should the pump be completely silent or is this "clicking" abnormal. It is a NEW pump and not a rebuild! Thanks....Bobby
Sep 9, 2006 at 5:56 AM
MERLIN2021
  • 17,250 POSTS
Some noise is normal, it's usually a soft whine not a clicking. Have you pressure tested the new pump?
Mar 6, 2007 at 9:08 AM
MIAMIBOB
No, I have not pressure tested the pump as the car runs perfect. I was just interested in the fact that the NEW Carter Pump is noiser than the original Ford Pump. At idle I can hear it from inside the car - maybe I am being over sensitive??
Mar 6, 2007 at 11:23 AM
MIAMIBOB
Yes, it is a "whine", not a click. Hope this helps...
Mar 8, 2007 at 1:22 PM
MERLIN2021
  • 17,250 POSTS
In those years yes you can hear the pump!
Mar 8, 2007 at 6:35 PM
MIAMIBOB
Thanks for the speedy reply! The reason I asked is because when I had the original Ford Pump it was quiet! This pump (Carter) is certainly louder. However, the car runs well so I hope what I hear is normal and not a defective pump with a shorter than normal life span!!
Mar 9, 2007 at 1:49 AM
MERLIN2021
  • 17,250 POSTS
Did you get a warrantee? Why not wait and see for a few weeks, I had an 86 Town Car and also did a fuel pump in it...they do whine a bit!
Mar 9, 2007 at 5:29 AM
302ERNIE
  • 9 POSTS
THEY ALL WHINE AND WHEN YOU HEAR WITH KEY ON ITS DOING ITS JOB ITS PUMPING DONT WORRY BE HAPPY ROLL ON
Jan 30, 2009 at 6:59 AM
Suggested Repair
A soft fuel-pump whine is normal on these cars, especially with the key on while the pump primes. No repair is indicated while the car runs well; confirm fuel pressure if concerned, keep the warranty, and monitor for a few weeks.
Conversation Summary
The owner replaced the fuel pump on a 1987 Mercury Grand Marquis with a new Carter unit and found it louder than the original Ford pump. After clarifying that the sound is a whine rather than a click, experts said some whine is normal on these years and that hearing the pump with the key on means it is priming. They suggested a pressure test if desired, using the warranty, and waiting a few weeks because the car runs well.
