Brake Light Wiring
CCSANDY
  • MERCURY MARQUIS
I have a 97 Mercury Grand Marquis and am trying to put a brakelight/backup light flashing unit (for EMS service). Which wire is the brakelight wire as there are 3 wires that connect to the assembly.
thanks
Sunday, March 11th, 2007 AT 9:48 PM
MIKE H R
  • 3,094 POSTS
One wire would go to the brake ligts, the second would go to the back up lights and the third would go to the power source.
Monday, March 12th, 2007 AT 9:57 PM
CCSANDY
Actually the back up light wiring is completely separate. The tail light/ turn signal/ brake light assembly has 3 wires plus the ground that go into the assembly.
I guess i'll just have to turn them each on individually and test the wire for current.
Monday, March 12th, 2007 AT 10:32 PM
MIKE H R
  • 3,094 POSTS
What kind of flasher is it? I looked in the garage and found one that has 6 wires of course none of them are labeled, let me know what kind you have
Tuesday, March 13th, 2007 AT 8:56 AM
MERLIN2021
  • 17,250 POSTS
Are you talking about installing Wig Wag lights like the cops?
If so ya need more than a flashser! You need a solinoid set.
Tuesday, March 13th, 2007 AT 4:00 PM
