2002 Mercury Marquis no start.
BENCRICH28
  • 2002 MERCURY MARQUIS
  • V8
  • 38,300 MILES
I stopped at a store to make a purchase, the car was running great. About ten minute later when I came out from the store and tried to start the car it would crank, but not start up.
Sunday, August 29th, 2010 AT 2:35 PM
Cranks but no start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Monday, August 30th, 2010 AT 2:44 AM
