Thank your for your donation. A running engine will only die if it looses spark or fuel. You said that your were seeing a coolant warning light, have your ecm scanned for trouble codes. Since you have to reset the key to get it to start after it dies, it could be an ecm problem (computer), a failing coolant temperature sensor or the main power relay.
SPONSORED LINKS
Monday, December 15th, 2008 AT 3:04 PM
