2000 Mercury Marquis car will not run
CALDANNY
  • 2000 MERCURY MARQUIS
  • V8
  • 102,000 MILES
My car will start and idle fine. Sometimes when I put it in gear it seems to bog down and die. It keeps this up until I gun the engine in neutral then it runs fine for the rest of the day. It may run fine for a week or more then it goes back to the earlier problem. I had the ford dealer run a computer check and they said everything was ok. I also had them to put new plugs in the car. Still have the problem periodically. Help
Wednesday, November 18th, 2009 AT 4:17 PM
BMRFIXIT
  • 19,053 POSTS
I would suspect IAC as to be the problem, remove and clean
Wednesday, November 18th, 2009 AT 5:51 PM
CALDANNY
Wath is the IAC
Monday, November 23rd, 2009 AT 7:13 PM
BMRFIXIT
  • 19,053 POSTS
IAC :
Idle air control valve
located on the Throttle body
Monday, November 23rd, 2009 AT 7:21 PM
