1996 Mercury Marquis will not start when cold
LANDS0554
  • 1996 MERCURY MARQUIS
  • V8
  • 200,000 MILES
Have had this car 6 years and once in a blue moon it just wont start when cold. Everything else will work, fully charged battery. Once I had it towed to the ford dealer and when thay went to get it. It started right up and no cause was given as to why it would not start. Yesterday it would not start and I checked all the fuses and relays. Even called a tow truck. And you guessed it. It started. Since this car has no distributor where is the ignition modual.I went to a mechanic and he told me that this car may have a short or the ignition control modual was bad.
Wednesday, March 18th, 2009 AT 4:40 PM
BLACKOP555
  • 10,371 POSTS
Will it crank? Or not crank?
When it wont start check for spark on all cylinders. And check the fuel pressure.
Lets not guess and check till we can atleast narrow it down!
Wednesday, March 18th, 2009 AT 9:55 PM
LANDS0554
We had the car towed again yesterday and when the car got there it. Started right up. Have checked forall problems including spark and its there. Good fuel pressure. But wont start. When cold. And damp.I think the car has a thermal break problem with one of the sensors. Mass air flow or the magnetic timing pick up. Or it just likes a ride on the tow truck once in a while. No problem codes. Cranks fine. Has mind of its own. Thanks all
Friday, March 20th, 2009 AT 6:57 AM
BLACKOP555
  • 10,371 POSTS
Next time it wont start check for the spark on all cylinders. And check the fuel pressure.
Missing oen of those. Let me know what you find.
Friday, March 20th, 2009 AT 9:17 PM
HELPING YOU
  • 100 POSTS
Easy (fuel or ignition?) Check - when it crank/no starts pop a hose off somewhere the engine sucks air in and spray a two second blast of ether (starting fluid).
Friday, March 20th, 2009 AT 9:45 PM
BLACKOP555
  • 10,371 POSTS
You can try that when having someone crank it then spray in the fluid.
Saturday, March 21st, 2009 AT 11:24 AM
