1996 Mercury Marquis # 2 cylinder intermitent skipping
BCLEARPHOT
  • 1996 MERCURY MARQUIS
  • V8
  • 145,000 MILES
My 1996 Merc Marquis has a misfire in #2 cylinder. I is mainly noted when shifting from park to drive, and also just after shifting into the other gears.
Friday, December 26th, 2008 AT 11:49 AM
  • 109,885 POSTS
Hi:
First, does each cylender have its own coil pack? Also, when was the last tune up?
Tuesday, December 30th, 2008 AT 1:18 AM
BCLEARPHOT
Thanks for the response. Problem solved. # 3 plug wire is defective. I replaced #2 wire with a used one and the problem ceased. I guess it is time for a new set!
Tuesday, December 30th, 2008 AT 7:28 AM
  • 109,885 POSTS
Hi:
I recommend doing a general tune up. Replace the distributor cap, rotor, plug wires, plugs, fuel filter, and air filter if needed. If you haven't done it for some time, it would be a good preventative maintenance choice.
Good luck and have a great new year.
Tuesday, December 30th, 2008 AT 11:30 AM
