My fuel pump fuse keeps poping. I have replaced the o2 sensors and sparkplugs. And repleced fuel pump relay. I also went to a bigger fuse. But they just pop after about 30 seconds. I was told it is electrical but don't even know where to start. Any help would be useful. Thanks
SPONSORED LINKS
Monday, February 9th, 2009 AT 3:30 PM
MECHANIC
Don't increase the fuse size. Only use the recommended one. Now, either the fuel pump is shorted or there is a bear wire shorting. Remove the tank and check the wiring and the pump itself.
