1995 Mercury Marquis multiple elec failures, no start
HERNANDO2170
  • 1995 MERCURY MARQUIS
Electrical problem
1995 Mercury Marquis V8 Two Wheel Drive Automatic 120k miles
1995 Grand Marquis. Mom was driving, heard a "pop" near where PMC resides. Then stalled. Restarted then a pop under arm rest. Car halted. Will crank, no start. OBD2 will not test (no power), gauges all are maxed out when key turned to accessory, no power to seats, windows, etc also. No smoke or damage physically noted upon inspection. What is relation between obd2, seats, engine no start?
Friday, April 9th, 2010 AT 10:04 AM
KHLOW2008
  • 41,814 POSTS
Hi hernando2170,
Thank you for the donation.
The only thing that is common among the problems would be a blown main fuse cutting off the power supply.
Check the mains fuses to see if any are blown.
Sunday, April 11th, 2010 AT 6:14 AM
