1993 Mercury Marquis air bag light
41,000 MILES • V8 • 2WD • AUTOMATIC
MCMOTORS1
i recently bought this car and the air bag light will flash 4 times stop and then flash four more times. the dealer tells me this is a code 44 indicating that the right front crash sensor is either not pluged up or not grounded properlly. they checked this today and both appear to be fine. the only answer i got was we don't have any idea what could be causing the code and just how much do you want to spend on fixing the problem. any other ideas?
Feb 25, 2008 at 6:19 AM
2CARPRO JACK
  • 11,533 POSTS
You used a meter and checked continuity to ground? Then I would start doing a pin to pin test of the wiring from the sensor to and through any connectors all the way to the air bag module.
Feb 25, 2008 at 6:31 AM
