Hello
Thanks for the donation.
If the engine light is coming on intermittently, it may be that the component is slowly failing and causing the light to appear occasionally. The next time your engine light appears, (if you are near any stores) go to a part store such as AutoZone or Advance Auto Parts and they can scan for the code free of charge. This will help diagnosis the culprit of the engine light. If the vehicle is operating normal and all fluids check out good, it is probably a sensor starting to malfunction. There are thousands of vehicles that run perfect, but still have the annoying engine light illuminating.
Thanks for using 2CarPros. Com !
SPONSORED LINKS
Wednesday, January 21st, 2009 AT 10:39 PM
