1992 Mercury Marquis No start
MEEZ
  • 1992 MERCURY MARQUIS
  • V8
  • FWD
  • 100,000 MILES
When exiting from freeway car just cut off and now wont start. How much for electrical work for this vehicle?
Friday, September 17th, 2010 AT 5:45 PM
It depends on what the problem is.
Pick your symptoms:
**Cranks but no start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
**No crank at all/nothing/nada when key is engage to starting position.
Could be a blown fusible link, the starter, starter relay, park and neutral switch/transmission position switch and ignition switch assuming the battery and connections are good. Note:If it doesn't apply disregard.
Saturday, September 18th, 2010 AT 12:15 AM
