1992 Mercury Marquis compresser
LILLOS12
  • 1992 MERCURY MARQUIS
Air Conditioning problem
1992 Mercury Marquis V8 Front Wheel Drive Automatic
my air compresser will come on then stop come on then stop Everybody keeps telling me I need to add some refrigerant but the accumulator want take it in. The unit is blowing nice and hard on the inside it not blowing hot air but it want get cool at all Then on top of that if I try to run the air while driving the car cuts off
Tuesday, April 28th, 2009 AT 8:52 PM
BMRFIXIT
  • 19,053 POSTS
Have to use gauges and check system pressure
you may have restriction causing a high reading in return shutting off the compressor
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Wednesday, April 29th, 2009 AT 6:07 AM
