1992 Mercury Marquis burning oil
1992 MERCURY MARQUIS
157,869 MILES • V8 • 4WD • AUTOMATIC
BABYFACE2SEE
what to do if the car is burning oil
Mar 30, 2009 at 5:20 AM
EUGENE123
  • 273 POSTS
if the car is burning oil its a pretty big problem to fix because one of two things is happening either you have bad valve guide seals and they need replaced or you have bad piston rings and they need replaced, if its the seals then you have to have the head machined and new seals put in it, if its the rings then the motor has to be tore completely down and new rings have to be put on the pistons
Mar 30, 2009 at 7:18 AM
BABYFACE2SEE
for a women point of view about cars you are the next best thing. thanks for the answer. babyface
Mar 31, 2009 at 11:53 AM
