Engine Performance problem
1992 Mercury Marquis V8 Two Wheel Drive Automatic
My 92 Merc project has a new symptom. It cranks but won't light. If I stop cranking and retry, it lights right off. Well, it did, its getting worse now. Fresh reassembly on the engine, no leaks from the injectors, changed one of the crank sensors, the other will take more work to try. Fuel press, 50 PSI. Runs well once it starts (except for the other new symptom: ping/knock at low RPM and high load). Related? I suspect the MAP sensor, wherever that is located, but don't know about timing or mixture for sure. Any Ideas? gsollenberger@hotmail.com
Mar 17, 2010 at 6:11 PM
