1992 Mercury Marquis Engine dies at full throttle on inters
YORKSHIREBIGBOY
  • 1992 MERCURY MARQUIS
  • V8
  • 75,000 MILES
Driving on the interstate at 65 and the power dropped off, power steering dead, no indicator lights on dash. After 10 minutes, engine restarted but only got 2 miles and died the same way. Not one hint of an indicator light like alternator or low oil pressure when the engine quit. Oil level and trans levels OK. May have had an error code 40 on at the shop where it sits.
Thursday, March 12th, 2009 AT 2:40 PM
JAMES W.
  • 2,394 POSTS
First thought, going by the information you provided, is fuel pump. What did the shop say? Please advise.
Friday, March 13th, 2009 AT 1:05 AM
YORKSHIREBIGBOY
Hi Jim,
Fuel filter was a little blocked but it seems to have been the throttle position sensor. The old one was scraped up and worn by some rubbing it appears but the shop was able to get a error code that indicated it might be a problem. I have just been driving in town since the repair this morning. No problems yet. The fuel pump appears to have been working normally.
To be one the safe side, we had the ignition wiring replaced, too, as it was showing a good bit of corrosion at the contacts on both ends of the wiring.
Thanks.
Friday, March 13th, 2009 AT 5:33 PM
JAMES W.
  • 2,394 POSTS
Good, I hope that does it for you. A TPS replacement is a loooooooooooot cheaper an a fuel punp. Anything else, you know where to find us.
Friday, March 13th, 2009 AT 6:13 PM
