1991 Mercury Marquis wont start sometimes
MONTE PERKINS
  • 1991 MERCURY MARQUIS
Electrical problem
1991 Mercury Marquis V12 Two Wheel Drive Automatic? Miles
sometimes when I try to start the car I get nothing even the dash lights dont do anything. Then if I try again it might start. I checked my battery it was 11.86 even after trying to start it unsuccessfully. My battery is only a year old my starter is only 4 months old. This might be a coincidence but I tapped on the positive cable post with a wrench and it started. I also disconnected the coil wire and re-connected it and it started. Ive had the car 4 years ive never replaced coils or starter modules. Also last night when it started and I drove it home from work it lacked power even though it was 50 degrees out.
Saturday, December 27th, 2008 AT 2:56 PM
  • 109,885 POSTS
Hi:
If the car won't crank and did when you tapped on the terminal, that is where I would start. Remove the terminals clean, replace and tighten them.
Let me know if that helps.
Tuesday, December 30th, 2008 AT 1:16 AM
