1996 Mercury Cougar Coil Pack Shorts
That is strange. The fact that it runs good until it shorts out makes me think the PCM is doing its job. I know that if the plug wires have too high of resistance, that can fry a coil pack.
I would probably replace the plugs and wires if it was my car. They also call to apply Silicone Dielectric Compound to all ignition wire boots, and make sure they are fully seated. Check under the coil pack and make sure it is clean and dry. The silicone can be applied under the coil pack also. If these things dont correct the problem, I would suspect the PCM, although that is highly unlikely.
Suggested Repair
Replace the spark plugs and plug wires, since high wire resistance can damage a coil pack. Apply silicone dielectric compound to the ignition wire boots and under the coil pack, fully seat the boots, and confirm the area under the coil pack is clean and dry. If the short returns, suspect the PCM, though that is considered unlikely.
Conversation Summary
A 1996 Mercury Cougar 3.8 V6 with 138,000 miles began missing badly, died, and would not restart, with a hissing sound from the coil pack. Replacing the coil pack and fuse allowed it to start, but it soon missed, died, and shorted the new coil pack while blowing the fuse again. The expert said the PCM appeared to be working because the car ran until the short occurred, and advised replacing the plugs and wires, applying dielectric compound, seating the boots fully, and keeping the coil-pack area clean and dry. The PCM was mentioned only as an unlikely later possibility.
