2000 Mercury Cougar Alternator Problem
2000 MERCURY COUGAR
71,000 MILES • 6 CYL • 2WD • AUTOMATIC
NEWTROOPER
I just replaced my alt. and I am experiencing the exact same problems. The headlamps and alt. light on the dash flickers. The a/c blower motor and engine also surges. Prior to replacing the alt. I fully charged my battery. After charging it, I load tested it and it was good. With the new alt. on and no load, the alt. shows 14V. As soon as I put a load on it, the voltage starts surging anywhere fron 12V to 16V. I disconnected the main red wire from the alt and installed a temporary wire from alt. to batt. and problem still exists. If I take the alt out of the loop by completely disconnecting the wires from it, the problems go away.I think I may have another bad alt. although it is new. I'm looking for some confirmation on this or suggestions of what I may have missed. Thanks
Aug 10, 2009 at 7:25 PM
BLUELIGHTNIN6
  • CAR REPAIR CONTRIBUTOR
  • 16,542 POSTS
This is a recall issue for the 2000 V6 Cougars. The charging system wiring is at fault and needs to be replaced and re-routed by your local Ford dealer. Contact your dealer and give them your VIN to confirm your vehicle is indeed effected by the recall.
Aug 10, 2009 at 10:45 PM
NEWTROOPER
I have already replaced the fuse link that is inline with the alt. cable. I also tried a new cable without a fuse link and still have the same problem.
Aug 11, 2009 at 12:24 PM
BLUELIGHTNIN6
  • 16,542 POSTS
contact local Ford dealer to have recall fixed as stated above...
Aug 11, 2009 at 12:26 PM
NEWTROOPER
I already replaced the in line fusable link as well as a new cable fron alt. to battery.
Aug 11, 2009 at 12:27 PM
CHRISCUNDIFF
where is the line fusable link at
Jul 22, 2011 at 8:32 PM
