1997 Mercury Cougar Hazard switch
GENE BRANCH
Electrical problem
1997 Mercury Cougar V8 Automatic 95735 miles
I did not have stop lights check all fuses on bulbs and where ok. turned hazard lights on and they did not work. Wiggled the button and every started working. how much trouble is it to replace the switch
Jan 7, 2008 at 5:04 AM
BMRFIXIT
  • 19,053 POSTS
[quote:a0903c9980="Gene Branch"]Electrical problem
I did not have stop lights check all fuses on bulbs and where ok. turned hazard lights on and they did not work. Wiggled the button and every started working. how much trouble is it to replace the switch[/quote:a0903c9980]
about 3/4 hr
not bad of a job relatively easy
you need to remove the plastic cover
Jan 12, 2008 at 2:29 PM
