1998 Mercedes Benz SLK230 The kick down does not work
1998 MERCEDES BENZ SLK230
RICH0070
Engine Mechanical problem
1998 Mercedes Benz SLK230 4 cyl Automatic 62000 miles
The car stutters when the accelerator is pressed
hard for fast take off or to gain quick speed.
Jul 24, 2009 at 12:30 AM
IMPALASS
  • 3,112 POSTS
Hello –
This could be caused by many things such as, MAP sensor, TPS, MAF, VAF, a vacuum leak, weak fuel pump.
Also, your vehicle should have the plugs changed every 30,000 miles…….so if you haven’t then you are twice behind.
Let’s start simple and see what we have.
Please go to Auto Zone (AZ) or O’Reilly’s (OR) and for FREE they can pull the codes to the car. Most important: Once they check your codes, if they find something and you don’t get it fixed and need to get back with us, please make sure you tell us exactly what the code was, number and all. Example, if the code was E0568 O2 Sensor bad. Then make sure you give us all of that. While there for FREE also they can bring their tester out and check your battery and alternator.
Jul 28, 2009 at 3:30 PM
