1995 Mercedes Benz S600
1995 MERCEDES BENZ S600
110,000 MILES • V12 • 2WD • AUTOMATIC
VASAKS
There is black smoke coming from the exhaust of my car. It has all new spark plugs and air fliter. Six of the spark plugs on the right side are black and dirty buut six spark plugs on the left are still like new. What could the problem be?
Aug 11, 2008 at 7:13 PM
MASTERTECHTIM
  • 4,750 POSTS
possible leaking fuel pressure regulator flooding those cylinders
Aug 11, 2008 at 7:42 PM
COOLPHIL
  • 12 POSTS
check the electrical side high tension wires and electric distributor (distributor is located on the front right side of the engine covered with in the plastic casing and record the values, then check if it is proper, clean with contact sprays and use contact fluid to reassemble the lines. also do check the ignition coil for the right bank since that is the problem side.
May 25, 2009 at 6:06 AM
