Airmatic suspension issues
JANINE1
  • 7 POSTS
Ooh okay. Well how come you know so much about it? Where would I actually find this at and look it up
Saturday, September 1st, 2018 AT 12:08 PM (Merged)
HAROLDGENE
  • 7 POSTS
Well the same exact thing happened to me. I have an 05 Mercedes S500 and my air suspension went out on me. Mine was in the front. It toke me a while to save up money to fix it. But a friend told me about the conversion kits. I went to Strutmasters. Com and looked up my vehicle. And found it. The kit was 937.00 for the 4 wheels. I immediately called in and ordered it cause it was way better than 5000 thousand dollars. I just wanted me car fixed. But then realizing it was actually better. Came with a lifetime warranty. Who couldn't beat that.
JANINE1
  • 7 POSTS
Ooh okay. Well how is the ride with the conversion kit?
Saturday, September 1st, 2018 AT 12:09 PM (Merged)
HAROLDGENE
  • 7 POSTS
The ride is just as great cant tell any kind of difference.
SERATH
  • 2001 MERCEDES BENZ S500
  • V8
  • 91,000 MILES
Intermittent adjustments. Sometimes it the shocks lower then raise. Seems spontaneous. It is parked now and the front end is all the way down. I read the question about the failed pump due to a sticking relay. Seems as though this may be a failing relay? Any help would be greatly appreciated. I am going to do the repairs myself, the car is my landlords, so a little deeper info on how to repair would help as well. Thank you for taking the time to read this thread. I realize there is better things to do than answer peoples questions.
GFIMOTORCARS
  • 673 POSTS
If the vehicle is on the ground in the front and will not raise then yes you have a failed relay. However the airmatic pump gets fryed when the relay sticks in the on position, burning the pump and the 40amp maxi fuse in this circuit. You will have to replace the 40amp maxi fuse, the airmatic pump and the relay. The relay and fuse are located in the fuse box on the passanger side engine compartment. Look for the 40 amp maxi fuse in this box. If it's blown then this is your problem. If not then you have leaking strut towers for the front shocks. This is not a repair that can be done at home as it requires special MB tools to perform. Let me know what you find and if necessary I can walk you through the replacement of the air pump. It's not terribly difficult to replace.
JANINE1
  • 7 POSTS
So you got the kit. Do u just take it to any shop or the dealer to put it on?
HAROLDGENE
  • 7 POSTS
Yeah I toke it to a shop and had it fixed a little over a grand to fix it but totally worth it. I advise you to check them out. There customer service was great.
JANINE1
  • 7 POSTS
I definitely will do that. Thanks for your help.
2CP-ARCHIVES
  • 4,540 POSTS
  • 68,000 MILES
What does airmatic to low mean on a mercedes benz on an S500 on a 2001
KHLOW2008
  • 41,814 POSTS
Do you mean too low? When vehicle height is lower than expected, the warning would come on. Is it happening all the time and is vehicle height and ride ok?
