1989 Mercedes 420SEL Overnight No-Start
MERCEDES BENZ
SGBONDO
I have a 1989 Mercedes 420SEL and I have being problems with the battery: the car will start all day long but will not start when it stays overnight. I have taken it to mechanics and they could not identify the problem. The problem started when the mechanic replaced the alternetor and since then I have not been able to use my car, almost two years ago. Does anyone has any suggestions?
Jan 5, 2007 at 7:13 AM
BRUCE HUNT
  • 3,754 POSTS
It could be alternator related, but with a volt-ohm meter and the engine running, check the volts on the battery. It should be 14 or over. I would also recommend unhooking a fuse at a time and note the spark of the positive cable as it is touched back on the battery. Something is discharging the battery. Once the spark stops and the fuse for that circuit is put back in and sparks the connection again you need to investigate the items on that circuit.
Jan 5, 2007 at 8:47 AM
Suggested Repair
With the engine running, measure battery voltage; it should be about 14 volts or higher, which may indicate an alternator charging problem. To find a drain, pull fuses one at a time and watch for a spark when the positive cable is touched back to the battery. When the spark stops, reinstall that fuse; if the spark returns, inspect the components on that circuit.
Conversation Summary
The owner of a 1989 Mercedes 420SEL says the car starts during the day but will not start after sitting overnight. The problem began after an alternator replacement, and mechanics have not found the cause. An expert recommends checking charging voltage with the engine running and isolating a battery drain by pulling fuses one at a time, then inspecting the circuit that stops the spark at the positive battery cable.
