2001 Mercedes E430 Camber Pull
MERCEDES BENZ
CAR5
2001 e430 with 60,000 miles. Hit the side of the front let tire into curb at 5-10 mph. Left front tire is out of alignment (positive camber of ~.8 instead of (-.5). Have been to 3 body shops and many weeks at dealer and now nobody can find the problem. Replaced upper and lower control arm, subframe (cradle), and spindle (knuckle), tire and wheel, and a broken spring (havent messed with shock assembly. Two different body shops said the frame is not bent. Dealer doesn't know where to turn next. Any ideas - car pulls to the left and wears tires - will be valueless if unfixable.
Thanks!
Aug 27, 2007 at 9:27 AM
SERVICE WRITER
  • 9,123 POSTS
It sounds like there may have been a wrong part put on. The knuckle should have taken care of the camber within reason. I would recheck the part numbers to be sure they are the correct ones for that model. I assume parts were new and dealer parts?
Aug 27, 2007 at 1:13 PM
CAR5
Thanks for your help. Some of the parts were replaced twice (cradle, control arm) because the dealer thought the parts might be wrong. The dealer put on the rest of the parts - I am not sure if they were used or new -- I'll ask.
Between the control arms and the tire, is there anything that can bend - something that the wheel attaches to, or perphaps the wheel itself (the wheel was replaced)?
Thanks - I'm desparate
Aug 27, 2007 at 1:38 PM
SERVICE WRITER
  • 9,123 POSTS
The knuckle would be that attaching point.
Aug 27, 2007 at 10:15 PM
Suggested Repair
Recheck part numbers for the knuckle and related suspension parts to confirm they are the correct parts for this E430. The knuckle is the wheel attaching point and should bring camber into range if the correct part is installed.
Conversation Summary
A 2001 Mercedes-Benz E430 has left-front positive camber, a left pull, and tire wear after a low-speed curb impact. Control arms, subframe, knuckle, wheel, tire, and a broken spring were replaced, and shops found no bent frame, but the problem remains. The expert advises verifying that the correct parts were installed and notes that the knuckle is the attaching point that should correct camber.
