A/C peformance
MERCEDES BENZ
DARRYLG
New A/C, freshly charged, the air dosnt blow very cold at all. I jumpered the pressure switch so the pump runs all the time, and it still dosnt blow very cold. you can tell its sort of working, just not good enough. Is there a spot in these systems that develops a restriction, a few 300E owners have metioned they have the same problem so it must be common,
any suggestions ?
Jun 11, 2006 at 6:22 AM
BERTROBINSON7
  • 8 POSTS
I have the 1995 C280 that also has air-conditioning problems one problem is the condenser leaks and need to be replaced. Common problem with Mercedes-Benz. Another problem is the climate control system on the dashboard once defective no one costs $800. A new one was installed. That was defective. If you want quality purchase a Lexus and stay away from Mercedes-Benz. They up really garbage
Jun 13, 2006 at 8:39 AM
