2004 Other Mercedes Benz Models Front Hood open warning ligh
2004 MERCEDES BENZ
63,000 MILES • 6 CYL • FWD • AUTOMATIC
FSPARODI
The hood open warning light is on in my car and the hood is closed! What should I do?
Dec 2, 2008 at 8:33 PM
GFIMOTORCARS
  • CAR REPAIR CONTRIBUTOR
  • 673 POSTS
Make sure that both latches are closing. You can ensure proper latch function by manually closing both latches. Open the hood and with a screw driver press both hood latches closed. Now check your dash for any warning. If the warning is gone you can be assured that one side of the hood is not closing fully. It the warning is still there your problem is more than likely a failed hood latch sensor. Note: remember to release your hood latches with the hood release before closing your hood.
Jan 3, 2009 at 9:20 PM
