1986 Mercedes 300E Frame Damage
MERCEDES BENZ
MUJTABA_BADAT
:shock:
My car (Mercedes 1986 300E; 200, 000 miles) skidded out of control and hit a curve while taking a left turn...
the passenger side wheel took a hard hit against the elevated sidewalk, after the collision, the wheel was jammed up against the fender of the car. I drove it home in that condition, as my house was only a couple of blocks away. I took it into a school autoshop and bought a used lower control arm. My shop teacher told me there is a possiblity of frame damage, but it would only be apparent after putting in the new parts and measuring the wheel displacement in relavence to eachother. He says that wheel is 1.5" further back than it should be. What can happen if I drive the car in such a state? The frame damage is somwhere behind the place where the inner part of the lower control arm connects. Does anyone know how much a frame repair of the sort would cost?
Nov 10, 2006 at 5:24 PM
2CARPRO JACK
  • 11,533 POSTS
you shouldnt drive it like that,its dangerous and you could lose control due to improper front end geometry. Call local bodyshops and see who they reccommend that does frame work
Nov 16, 2006 at 2:35 AM
MUJTABA_BADAT
what if you drive it really slow? maximum 50 km an hour (intercity travel)
Nov 16, 2006 at 10:46 AM
Suggested Repair
Do not drive the car, even slowly, because the rearward wheel position indicates improper front-end geometry and a risk of losing control. Have a body shop experienced in frame work inspect and repair the suspected frame damage, then remeasure wheel position and alignment.
Conversation Summary
A 1986 Mercedes-Benz 300E hit a curb, jamming the passenger-side wheel against the fender. After a used lower control arm was installed, the wheel measured about 1.5 inches too far back, suggesting possible frame damage behind the inner lower control arm mount. The owner asked about driving risks, repair cost, and whether slow driving would be safe. The expert advised against driving it because the improper geometry could cause loss of control and recommended contacting local body shops for a frame-repair referral.
