1994 Other Mercedes Benz Models TURN SIGNAL
1994 MERCEDES BENZ
148,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROBERTBENZ
I HAVE A 320 MERCEDES COUPE. THE TURN SIGNAL STOPPED WORKING. NIETHER DOES MY HAZZARD LIGHTD WORK. BUT A COUPLE OF DAY AGO I FLIPPED THE TURN SIGNAL (FORCE OF HABIT) AND IT BLINKED ONCE. PLEASE CAN SOME ONE TELL ME WHATS GOING ON. SIGNED ROBERT
Aug 14, 2008 at 12:58 PM
GFIMOTORCARS
  • 673 POSTS
You may want to check the turn signal relay first. After locating the relay in the fuse box pull it out and replace it with another relay from another slot that is the same part number. It may be your horn relay for example. After switching the two, turn the vehicle on (2nd accesory position) but don't start it, then check your turn signals. If they work then you need to replace the relay. If they don't you may have a failed combination switch (the turn signal lever assembly) that will need to be replaced.
Jan 6, 2009 at 6:22 AM
