2000 Mercedes Benz ML320 rough shifting 1st gear only
224,760 MILES • 6 CYL • 4WD • AUTOMATIC
SAMBUDDY
Filter in transmission found in bottom of pan.
rough shifting in and out of 1st gear. otherwise shifts smoothly.
Dec 9, 2009 at 10:33 AM
2CARPRO JACK
  • 11,533 POSTS
Was it serviced with the proper M/B fluid? Sounds like it may be a valve-body or solenoid issue. Has any work been done to the trans before? I dont see any TSB (Tech Service Bulletins) that pertain to harsh 1st gear shifts, except under full throttle.
Dec 11, 2009 at 1:09 PM
