2000 Mercedes Benz ML320 GEAR SHIFT LEVER WON'T COME OUT OF
2000 MERCEDES BENZ ML320
107,000 MILES • 6 CYL • AWD • AUTOMATIC
RPSTARR
  • 10 POSTS
PULLED INTO A PARKING LOT - AS I HIT THE BRAKES & TURNED INTO THE PARKING PLACE THE BAP/ESP LIGHT CAME ON - WENT INTO STORE & WHEN I CAME OUT THE CAR STARTED BUT THE BAP/ESP LIGHT STAYED ON & THE GEAR SHIFTER WOULD NOT COME OUT OF PARK (WHEN I APPLIED THE BRAKES) - HAD TO MANUALLY OVERRIDE TO GET OUT OF PARK - CAR DRIVES FINE - BAP/ESP LIGHT STAYS ON & IT LOCKS UP IN PARK SO YOU HAVE TO MANUALLY RELEASE SHIFTER EVERY TIME YOU DRIVE -
SEEMS LIKE SOMETHING "LET GO" DOWN BY THE BRAKE PEDAL - ANY SUGGESTIONS ???
Jan 28, 2010 at 7:08 AM
2CARPRO JACK
  • 11,533 POSTS
Check and see if the brake lights work.Sounds like the brake pedal switch may have quit working, which is used by the ESP systems and the shifter-lock
Jan 28, 2010 at 8:54 AM
JODIECARLSON
how do I manually release the shifter? My car is doing the same thing
Jan 1, 2011 at 6:32 AM
