P0170/P0110
The first thing I would do is to check all intake and vaccume hoses for leaks and breaks. These will cause these codes. If they are fine then check the voltage to the air mass sensor. There are one ground(brown wire), one 5 volt wire, one 12 volt wire, and one single wire. Any good digital volt meter will work. If the voltages are fine, then I would change the sensor.
SPONSORED LINKS
Friday, June 11th, 2010 AT 12:31 AM
